Hi dear friends
How can I use Normalized Mutual Information (NMI) for Clustering? like K-Means or DBSCAN
I attach the file
Thank's
You could build a process using the k-means and/or DBSCAN operators?
I used K_Means and DBSCAN, but I want to evaluate these methods by NMI.
You might want to check out the Mutual Information Matrix operator. See below.
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="7.5.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34"> <parameter key="csv_file" value="C:\Users\ThomasOtt\Downloads\AccXYZ.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="k_means" compatibility="7.5.001" expanded="true" height="82" name="Clustering" width="90" x="179" y="34"> <parameter key="k" value="5"/> </operator> <operator activated="true" class="extract_prototypes" compatibility="7.5.001" expanded="true" height="82" name="Extract Cluster Prototypes" width="90" x="313" y="34"/> <operator activated="true" class="mututal_information_matrix" compatibility="7.5.001" expanded="true" height="82" name="Mutual Information Matrix" width="90" x="447" y="34"/> <connect from_op="Read CSV" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Mutual Information Matrix" to_port="example set"/> <connect from_op="Mutual Information Matrix" from_port="example set" to_port="result 1"/> <connect from_op="Mutual Information Matrix" from_port="matrix" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
