Set parameter doesn't set parameter in loop
qwertz2
qwertz2 New Altair Community Member
edited November 5 in Community Q&A
Dear all,
This one is driving me mad... Basically, I took the tutorial of the set parameters operator and put a loop around it.
Result 1) Run the process and restart after each time the breakpoint has been reached. The log shows that parameters "C" and "degree" are not always the same.
Result 2) Now remove the breakpoint and run the process again. The log shows only a single value for "C" and "degree". Though the optimizer has delivered the correct values, the set parameters operator does not apply them without the breakpoint. Any ideas?!?
Best regards
Sachs
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Root">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.5.001" expanded="true" height="68" name="Polynomial" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Polynomial"/>
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute" value="label"/>
<operator activated="true" class="concurrency:loop_attributes" compatibility="7.5.001" expanded="true" height="103" name="Loop Attributes" width="90" x="313" y="34">
<operator activated="true" class="set_role" compatibility="7.5.001" expanded="true" height="82" name="Set Role" width="90" x="45" y="136">
<parameter key="attribute_name" value="%{loop_attribute}"/>
<operator activated="true" class="multiply" compatibility="7.5.001" expanded="true" height="103" name="Multiply" width="90" x="179" y="136"/>
<operator activated="true" breakpoints="after" class="optimize_parameters_grid" compatibility="6.0.003" expanded="true" height="103" name="Optimize Parameters (Grid)" width="90" x="313" y="34">
<list key="parameters">
<parameter key="Learner.C" value="50,100,150,200,250"/>
<parameter key="Learner.degree" value="1,2,3,4,5"/>
</list>
<operator activated="true" class="concurrency:cross_validation" compatibility="7.5.001" expanded="true" height="145" name="Cross Validation" width="90" x="313" y="34">
<parameter key="number_of_folds" value="3"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="7.5.001" expanded="true" height="82" name="Learner" width="90" x="45" y="34">
<parameter key="svm_type" value="epsilon-SVR"/>
<parameter key="kernel_type" value="poly"/>
<parameter key="degree" value="5"/>
<parameter key="C" value="250"/>
<parameter key="epsilon" value="0.01"/>
<list key="class_weights"/>
<connect from_port="training set" to_op="Learner" to_port="training set"/>
<connect from_op="Learner" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
<operator activated="true" class="performance" compatibility="7.5.001" expanded="true" height="82" name="Performance" width="90" x="179" y="34"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="performance 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<operator activated="true" class="set_parameters" compatibility="7.5.001" expanded="true" height="82" name="Set Parameters" width="90" x="447" y="34">
<list key="name_map">
<parameter key="Learner" value="OptimalLearner"/>
</list>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="7.5.001" expanded="true" height="82" name="OptimalLearner" width="90" x="581" y="187">
<parameter key="degree" value="1"/>
<parameter key="C" value="100"/>
<operator activated="true" class="log" compatibility="7.5.001" expanded="true" height="82" name="Log" width="90" x="715" y="187">
<list key="log">
<parameter key="C" value="operator.OptimalLearner.parameter.C"/>
<parameter key="degree" value="operator.OptimalLearner.parameter.degree"/>
</list>
<connect from_port="input 1" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="OptimalLearner" to_port="training set"/>
<connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_op="Set Parameters" to_port="parameter set"/>
<connect from_op="Set Parameters" from_port="parameter set" to_port="output 1"/>
<connect from_op="OptimalLearner" from_port="exampleSet" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="output 2"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<connect from_op="Polynomial" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Loop Attributes" to_port="input 1"/>
<connect from_op="Loop Attributes" from_port="output 1" to_port="result 1"/>
<connect from_op="Loop Attributes" from_port="output 2" to_port="result 2"/>
</process>
</process>
Best Answer
  • Andrew
    Andrew New Altair Community Member
    Answer ✓
    Hello
    It's probably because the Loop operator is processing in parallel so the order is indeterminate. Check the "reuse results" parameter to see if that makes a difference.
    Andrew
  • Andrew
    Answer ✓
    Hello
    Andrew
  • qwertz2
    Thumbs up! That was it! Though I am familiar with this function I didn't take it into account at all. In my setting I cannot reuse the results but the disabling of parallel execution lead to success as well!
    Cheers
    Sachs
