RM Server putting all tables in the Postgres public schema
rachel_lomasky
rachel_lomasky New Altair Community Member
I got RM talking to Postgres, but instead of putting its tables in the schema I indicated, they are all in the public schema.  Is there a way around this?
<!DOCTYPE properties SYSTEM "http://java.sun.com/dtd/properties.dtd">
<properties>
<entry key="db_driver_path">data/jdbc/postgresql-9.3-1101-jdbc4.jar</entry>
<entry key="db_driver_path_is_relative">true</entry>
<entry key="db_driverclass">org.postgresql.Driver</entry>
<entry key="db_password">mypass</entry>
<entry key="db_port">5432</entry>
<entry key="db_schema">rapidminer</entry>
<entry key="db_system">PostgreSQL</entry>
<entry key="db_url">mymachine.cy5mwbb5zo5d.us-east-1.rds.amazonaws.com</entry>
<entry key="db_user">myuser</entry>
<entry key="server_service_id_overwrite">null</entry>
<entry key="eula_accepted">true</entry>
<entry key="server_port">8080</entry>
<entry key="mail_password"/>
<entry key="installation_directory">/opt/rapidminer</entry>
<entry key="license_key">mykey</entry>
<entry key="server_host">127.0.0.1</entry>
<entry key="server_register_as_service">false</entry>
<entry key="mail_port">25</entry>
<entry key="server_service_linux_variant">SUSE</entry>
<entry key="mail_sender"/>
<entry key="memory_max">2048</entry>
<entry key="radoop_proxy_port">1081</entry>
<entry key="mail_url"/>
<entry key="server_service_name">RapidMiner_Server_7_5_1</entry>
<entry key="java_home"/>
<entry key="server_service_id">RMS751SVC</entry>
<entry key="server_host_bind_only">false</entry>
<entry key="radoop_proxy_enable">false</entry>
<entry key="mail_user"/>
</properties>
Welcome!
Best Answer
  • rachel_lomasky
    Answer ✓
    The db_url is:
    <entry key="db_url">my_database.1.2.3.4/my_schema</entry>, where 1.2.3.4 is the IP of my database machine.
  • Thomas_Ott
    @BalazsBarany any pointers for @rachel_lomasky?
  • rachel_lomasky
    Answer ✓
    The db_url is:
  • BalazsBaranyRM
    BalazsBaranyRM New Altair Community Member
    Just to clarify:
    Some other databases have a different meaning of schema than PostgreSQL.
    In PostgreSQL, there's a "database" that can contain schemas. The default schema is "public". You can create schemas with "CREATE SCHEMA myschema" and deselect the "use default schema" checkbox in RapidMiner to refer your schema.
    This works well, I use RapidMiner heavily with PostgreSQL.
  • rachel_lomasky
    That's for the RM configuration tables, not the data that I am working with?
Welcome!
Welcome!
