After following the steps on https://docs.rapidminer.com/server/administration/installing-extensions.html , I was not able to see the extensions in the Server. I restarted the computer and they were there.
Michel
Are you sure that you did step 5 (restart RapidMiner Server)? This should be sufficient and is what happened implicitly when you restartet the computer.
Cheers,
Ingo
