Qlik says that:
"What are the limitations of Personal Edition?
There are only two limitations while using QlikView with the Personal Edition license:
- QlikView Personal Edition works with local files only; you cannot share your QlikView file with another unregistered user, or load a QlikView file from another user.
- You cannot import an entire document layout (sheets/objects/security settings, etc. without the data) into QlikView Personal Edition.
"(https://community.qlik.com/docs/DOC-1799)
Can I use the free version( Personal Edition) of Qlik  with Rapidminer Server?
Thanks,
Michel
