hello.i want to use deep learning operator..in this way i encounter by somthing that it is said "h2o-3.8.2.6_1-py2.py3-none-any"!!what is this?how can i install this"h2o"in rapidminer?
1. Did you install Radoop and configure your connection to your Hadoop cluster?
2. You have to use SparkRM to use the H2O Deep Learning operator on the Cluster.
3. You can't install H2O into RapidMiner, you can only use the H2O operators OR pull it in via their Python API using our Python Script operator.
