Is it possible to loop over processes in a repository?
earmijo
earmijo New Altair Community Member
Let me give you the context of my question. I'm adapting Fabian Temme's (or Thomas Ott's? I wasn't clear) nice blog entry on Model Management.
I have a collection of processes in a folder named "Algorithms". All of them are processes that take the same dataset and produce the same outputs (model, performance).
I would like to write another process that would loop over the repository of processes and execute them all. Currently my process looks like this:
I want to extend my example to 15-20 different processes with different parameters. Any chance I can loop thru them? I tried "Loop Repository" but couldn't make it work.
Thanks in advance for any help,
\E
Best Answer
  • kayman
    kayman New Altair Community Member
    Answer ✓
    What if you create an example set (like an external csv or so), which has your process names as values, and you loop through that one? Using an extract macro you can then get the name of your process, and use that as an input to call your process. You could either call it directly or use it as a trigger in a branched process loop.
    Not very elegant but it should do the job I believe.
  • kayman
    Answer ✓
  • Edin_Klapic
    Edin_Klapic New Altair Community Member
    Hi \E,
    looping over processes can only be done with a workaround. Unfortunately, there is no built-in solution for that.
    The attached process works if you have the processes on a local filesystem - Not on RapidMiner Server.
    Do not store the process in the folder you want to execute - otherwise you might run into issues.
    Best,
    Edin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="concurrency:loop_files" compatibility="7.5.001" expanded="true" height="82" name="Loop Files" width="90" x="112" y="34">
    <parameter key="directory" value="C:\Users\EdinKlapic\.RapidMiner\repositories\Local Repository\Community\crawl web"/>
    <parameter key="filter_type" value="regex"/>
    <parameter key="filter_by_regex" value=".*\.rmp"/>
    <parameter key="enable_macros" value="true"/>
    <operator activated="true" class="generate_macro" compatibility="7.5.001" expanded="true" height="82" name="Generate Macro" width="90" x="112" y="34">
    <parameter key="file_name" value="replace(%{file_name},&quot;.rmp&quot;,&quot;&quot;)"/>
    </list>
    <operator activated="true" class="productivity:execute_process" compatibility="7.5.001" expanded="true" height="82" name="Execute Process" width="90" x="246" y="34">
    <parameter key="process_location" value="crawl web/%{file_name}"/>
    <list key="macros"/>
    <connect from_op="Generate Macro" from_port="through 1" to_op="Execute Process" to_port="input 1"/>
    <portSpacing port="source_file object" spacing="0"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    <connect from_op="Loop Files" from_port="output 1" to_port="result 1"/>
    </process>
    </process>
  • bhupendra_patil
    bhupendra_patil New Altair Community Member
    to make it easier what @kayman suggested, you can use some operators from operator toolbox extension , please explore the "create exampleset" -- here you can add a list of process you want to execute
    Also there are operators to set parameters using exampleset, set macros using exampleset,
  • earmijo
    Kayman, Edin, Bhupendra:
    All of your suggestions work perfectly. Thank you very much for your time.
    \E
