Hi All,
I'm new to Rapidminer. Does Rapidminer supports MapR? I tried to connecting MapR using Other (Hadoop 2.x line) option in Rapidminer but no luck. There are no documentation regarding this as well.
Many thanks.
update 2018 - RapidMiner now supports MapR
https://docs.rapidminer.com/latest/radoop/installation/distribution-notes.html
We don't support MapR at the moment. In fact, what we don't support is mainly MapR's security, which is quite different from that in the other distributions. If you tried to connect to an unsecured MapR using Radoop, you would be able to.
That said, supporting MapR is in our mid-term plans. It won't be there in the immediate future, but it's certainly in our radar.
Regards.
@jpuente wrote: Hi, We don't support MapR at the moment. In fact, what we don't support is mainly MapR's security, which is quite different from that in the other distributions. If you tried to connect to an unsecured MapR using Radoop, you would be able to. That said, supporting MapR is in our mid-term plans. It won't be there in the immediate future, but it's certainly in our radar. Regards.
Hi jpuente,
Thanks for the explanation.
Our MapR is unsecured. Is there any spesific configuration on Radoop since MapR doesn't have namenode?
Well, Radoop only supports Hive/HDFS as a data layer, not the MapR-FS, so probably you won't be able to connect in your case.
