select attributes with at least one entry
sgenzer
sgenzer
Hi...having a brain freeze with what should be a very simple thing.  I have a data set with 250+ nominal and numerical attributes, many of which are completely empty (all missing values).  Others have perhaps one or two entries with the rest missing.  How do I eliminate all attributes, nominal and numerical, that only have ALL missing values?  I have tried every combination of operators (including Ingo's workaround posted a while ago) to no avail.
Scott
Welcome!
Best Answer
  • MartinLiebig
    MartinLiebig
    Answer ✓
    have a look at the attached process. You can filter on >X or <X number of missings.
    ~Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.4.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="retrieve" compatibility="7.4.000" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="34">
    <parameter key="repository_entry" value="//Samples/data/Golf"/>
    <operator activated="true" class="generate_attributes" compatibility="7.4.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34">
    <parameter key="only_missing" value="str(0/0)"/>
    </list>
    <operator activated="true" class="aggregate" compatibility="7.4.000" expanded="true" height="82" name="Aggregate" width="90" x="380" y="136">
    <parameter key="use_default_aggregation" value="true"/>
    <parameter key="default_aggregation_function" value="count (ignoring missings)"/>
    <parameter key="Wind" value="count (ignoring missings)"/>
    </list>
    <operator activated="true" class="rename_by_replacing" compatibility="7.4.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="514" y="34">
    <parameter key="replace_what" value="countWithOutMissings\((.+)\)"/>
    <parameter key="replace_by" value="$1"/>
    <operator activated="true" class="select_attributes" compatibility="7.4.000" expanded="true" height="82" name="Select Attributes" width="90" x="648" y="34">
    <parameter key="attribute_filter_type" value="numeric_value_filter"/>
    <parameter key="numeric_condition" value="&gt;1"/>
    <operator activated="true" class="data_to_weights" compatibility="7.4.000" expanded="true" height="82" name="Data to Weights" width="90" x="782" y="34"/>
    <operator activated="true" class="select_by_weights" compatibility="7.4.000" expanded="true" height="103" name="Select by Weights" width="90" x="916" y="136"/>
    <connect from_op="Retrieve Golf" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
    <connect from_op="Aggregate" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/>
    <connect from_op="Aggregate" from_port="original" to_op="Select by Weights" to_port="example set input"/>
    <connect from_op="Rename by Replacing" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="example set output" to_op="Data to Weights" to_port="example set"/>
    <connect from_op="Data to Weights" from_port="weights" to_op="Select by Weights" to_port="weights"/>
    <connect from_op="Select by Weights" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
  • Telcontar120
    Telcontar120 New Altair Community Member
    Remove Useless Attributes doesn't work on missings?  What if you first run a Replace Missing Values with a constant value and then use it?
  • MartinLiebig
    MartinLiebig
    Answer ✓
    ~Martin
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    </list>
    </list>
    </process>
    </process>
  • sgenzer
    sgenzer
    that works very nicely.  Thanks, Martin.
    Scott
  • sgenzer
    sgenzer
    yes tried that for a while.  It does not appear to work because of the mixture of nominal and numerical atts...Martin's solution takes care of that.  :)
Welcome!
Welcome!
