hi,
previously, I used Performance(Classification) in the old Validation (X-Validation) Operator.
when I activated the cases for performance measures like weighted mean precision, margin, squared error etc. it was showed in the log operator outside the X-Validation.
However, with the new Cross Validation operator, the values of the Performance operator doesn't show anymore... its missing values instead "?"...
I think its a bug...
here is a XML example process with iris data to show the problem..
I could not find the old X-Validation anymore.. therefore the problem should be fixed soon please as I am constructing my wm_FScore out of the wm_Recall and wm_Precision
<?xml version="1.0" encoding="UTF-8"?><process version="7.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.4.000" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="85">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="x_validation" compatibility="7.4.000" expanded="true" height="124" name="Validation" width="90" x="447" y="85">
<parameter key="number_of_validations" value="4"/>
<parameter key="sampling_type" value="stratified sampling"/>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="7.4.000" expanded="true" height="82" name="SVM" width="90" x="112" y="34">
<parameter key="gamma" value="0.007170375144641631"/>
<parameter key="C" value="227500.0"/>
<list key="class_weights"/>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.4.000" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<operator activated="true" class="performance_classification" compatibility="7.4.000" expanded="true" height="82" name="Performance" width="90" x="313" y="34">
<parameter key="kappa" value="true"/>
<parameter key="weighted_mean_recall" value="true"/>
<parameter key="weighted_mean_precision" value="true"/>
<parameter key="correlation" value="true"/>
<parameter key="squared_correlation" value="true"/>
<parameter key="margin" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="log" compatibility="7.4.000" expanded="true" height="82" name="Log" width="90" x="581" y="136">
<list key="log">
<parameter key="xvalperf" value="operator.Validation.value.performance"/>
<parameter key="perfperf" value="operator.Performance.value.accuracy"/>
<parameter key="perfkappa" value="operator.Performance.value.kappa"/>
<parameter key="perfcorr" value="operator.Performance.value.correlation"/>
<parameter key="perfwmprec" value="operator.Performance.value.weighted_mean_precision"/>
<parameter key="perfwmrec" value="operator.Performance.value.weighted_mean_recall"/>
</list>
<operator activated="true" class="retrieve" compatibility="7.4.000" expanded="true" height="68" name="Retrieve Iris (2)" width="90" x="112" y="340">
<operator activated="true" class="concurrency:cross_validation" compatibility="7.4.000" expanded="true" height="145" name="Cross Validation" width="90" x="447" y="289">
<operator activated="true" class="support_vector_machine_libsvm" compatibility="7.4.000" expanded="true" height="82" name="SVM (2)" width="90" x="45" y="34">
<connect from_port="training set" to_op="SVM (2)" to_port="training set"/>
<connect from_op="SVM (2)" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.4.000" expanded="true" height="82" name="Apply Model (2)" width="90" x="112" y="34">
<operator activated="true" class="performance_classification" compatibility="7.4.000" expanded="true" height="82" name="Performance (2)" width="90" x="313" y="34">
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance (2)" from_port="example set" to_port="test set results"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<operator activated="true" class="log" compatibility="7.4.000" expanded="true" height="82" name="Log (2)" width="90" x="581" y="340">
<list key="log">
<parameter key="perfkappa" value="operator.Performance (2).value.kappa"/>
<parameter key="perfcorr" value="operator.Performance (2).value.correlation"/>
<parameter key="perfwmprec" value="operator.Performance (2).value.weighted_mean_precision"/>
<parameter key="perfwmrec" value="operator.Performance (2).value.weighted_mean_recall"/>
</list>
<connect from_op="Retrieve Iris" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="result 1"/>
<connect from_op="Retrieve Iris (2)" from_port="output" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="performance 1" to_op="Log (2)" to_port="through 1"/>
<connect from_op="Log (2)" from_port="through 1" to_port="result 2"/>
</process>
</process>
