If I wanted to utilize Cloudera with RapidMiner - is it possible to run distributed computing?
Thanks,
Craig
RapidMiner Radoop allows you to use the Cloudera Hadoop distribution, this allows you push data science processes to the Hadoop cluster and run them in a distributed fashion.
Thanks T.
I also found the list of compatable service providers: http://docs.rapidminer.com/radoop/installation/compatibility.html
