Time Series Forecasting for Data
glybentta
glybentta New Altair Community Member
I have a marine dataset with 3 attributes (Year, Species [categorical], Catch). I need to forecast the catch of each individual species(there are 8 species) for next 5 years. Is it possible with Windowing operator? Can someone please help me out with this? Thanks in advance
  • Telcontar120
    Telcontar120 New Altair Community Member
    Of course it is possible :-), with RapidMiner it almost always is.
    However, in these types of cases, you may find that you need to create 5 separate forecast models.  Of course, if the data structure is the same for each, then you can easily reuse the same modeling setup and just loop through the setup by selecting only examples for each species separately for each run.
    If you install the Time Series extension, there should be a new template available on the Studio startup page (or you can navigate there from your repository under Samples under Templates) which will help you get your first process set up.  Take a look at the attached screenshot.
  • Thomas_Ott
  • glybentta
    Thank you Brian T for you quick reply. I went through the above mentioned templete and the link provided by Thomas Ott. I understood the concept of windowing, but I could only forecast the values which are already present in my ExampleSet. I have data from 1980-2016. So with the windowing operator with parameters as window size = 5, step size = 1, horizon= 1, I could only get the forecasted value of 2016 which is already present in my dataset. I tried changing the forecast models(Linear regression, SVM etc) but the forecasted output dint change at all. I dont know wether I had gone wrong somewhere. What if I wanted to forecast value of 2017 using the previous 5 years data?
  • Thomas_Ott
    Take a look at the sample processes I posts here: http://community.rapidminer.com/t5/RapidMiner-Studio/Recall-Error/m-p/37302#U37302
    This process was taking out of Vijay and Bala's book (Chp 10) and uses the existing time series to forecast into the future based on the model it created. It's really neat but you'll have to tweak it to your data set.
