RM has a "loop data sets" component.
My data sets are saved in a database. Is there is a way to loop through all database tables?
hi,
not with one operator. You can write a SQL statement generating you table of table names and use a Loop Values on it to get each table name as a macro. You can then use this table in the loop.
~Martin
Yes, you can use the Loop Repository operator and instead of pointing at your local repository point at the //DB/ where your stored connections are.
Below is a quick example.
<?xml version="1.0" encoding="UTF-8"?><process version="7.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="loop_repository" compatibility="7.4.000" expanded="true" height="82" name="Loop Repository" width="90" x="179" y="136"> <parameter key="repository_folder" value="//DB/DemoDataStore/Example Sets/"/> <parameter key="entry_type" value="IOObject"/> <process expanded="true"> <connect from_port="repository object" to_port="out 1"/> <portSpacing port="source_repository object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Loop Repository" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
