Set Role
fedayncarica
fedayncarica New Altair Community Member
Good Morning, before I had built a process for the "k-nn" and with a specific dataset it worked well. Now I changed the dataset (attached) and I can not run the process. The system tells me I can not find the specified attributes. Can someone help me? Tomorrow I have a deadline.
The process is attached below! In this email attaching the dataset.
Best
Damian
  • fedayncarica
    This is process.
  • Thomas_Ott
    The great thing about RapidMiner is that it checks your metadata before you even click "run."  If you've changed your dataset, and there are new names or new roles, then chances are that one of your parameter settings is complain.  Trace through your process and find the operators that have a "!" in triangle sign, those are the operators where the metadata condition is not met. Double check that right attribute is available to the operator and in the right data format and role.
  • Andrew
    Andrew New Altair Community Member
    The read CSV operator does not know how to read the CSV files it is presented with. You could run the Import Configuration Wizard on an example CSV file to fix this. Unfortunately, however, I can see that the files you provided have different attributes so this makes it impossible until you have made all the csv files have identical headers.
    Then I notice that following operators are referring to attributes that don't exist. These can be fixed by changing the parameters for these operator.
    Regards
    Andrew
  • fedayncarica
    Hi Andrew, yes.. I had created the process for a given dataset, now how can I change?
    Best,
    Damian
  • Thomas_Ott
    Try rerunning the Import Wizard on the Read CSV as Andrew pointed out. Go thru all the steps of the wizard to make sure you're getting the data you need/want.
  • Andrew
    Also, each of the data files provided has different attributes. This means your process is doomed to fail.
    Andrew
