Parameterizing the database connection
User: "rachel_lomasky"
New Altair Community Member
Updated by Jocelyn
I have a process that makes several database touches (read/write/execute sql).  Is it possible to parameterize the database connection?  I'd like to be able to switch it to write to the dev/staging/prod databases without having to manually change each operator.
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    i think the most convinient way is to use a Subprocess or Branch opertor and choose depending on a macro.
    Antoher way could be to use a macro in the Read Database COnnection setting. You need to put this one into the XML though.
    Best,
    Martin
