Image extension - Shape of an Object
What i sthe best approach to do the following
From a photo image that contain an object ( suppose we consider a bag,.... )
I want extract shape features
I try
Segmentation of the object
Extract shape features with the operator
Selection of main interesting segment ????
Is there a way to have a 1 main segment with the border of the subject
Have someone hint on it
Thanks in advance
Best Answer
Hello Filippo,
these steps are correct:
For selecting only one segment, you have to classifier for these segments. There is operator for it - Filter Segments by Example Set. For this, you need ExampleSet with segment IDs which you want to preserve.
Also you need label for these segments. You can do it manually by putting breakpoint after segmentation and in result view edit the label by left and right mouse button. Or you can set image mask and use Calculate Segments Label By Mask operator to automatically calculate segment's labels.
Best wishes
Vaclav
Hello Filippo,
Best wishes
Vaclav
