Hi RapidMiner,
I followed this tutorial (http://community.rapidminer.com/t5/RapidMiner-Studio-Knowledge-Base/Cross-Validation-of-R-Python-Models/ta-p/31978) to do cross validation of R Random Forest regression model but encountered an error as in the attached photo. However, the same R scripts work well for the single validation as in the attached process (Single-Validation.rmp). I also attached the cross validation process here. Do you have any idea?
Thanks a lot!
Best Regards,
phivu
Please move your operator "R Apply Model" down a bit. Then you can see that its second input port is not connected to the tes-port. After fixing the connection it should work.
Best,
Gisa
The script error appears to be looking for the data. Check your R script for where the data is being loaded from.
Thanks Gisa!
