<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
<parameter key="logfile" value="C:\Users\Damiano\Downloads\log1Damiano.csv"/>
<process expanded="true">
<operator activated="true" class="loop_files" compatibility="7.3.001" expanded="true" height="82" name="Loop Files" width="90" x="179" y="34">
<parameter key="directory" value="C:\Users\Damiano\Desktop\Loop Process"/>
<parameter key="filtered_string" value="file name (last part of the path)"/>
<parameter key="file_name_macro" value="file_name"/>
<parameter key="file_path_macro" value="file_path"/>
<parameter key="parent_path_macro" value="parent_path"/>
<parameter key="recursive" value="false"/>
<parameter key="iterate_over_files" value="true"/>
<parameter key="iterate_over_subdirs" value="false"/>
<operator activated="true" class="read_csv" compatibility="7.3.001" expanded="true" height="68" name="Read CSV" width="90" x="112" y="34">
<parameter key="column_separators" value=";"/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<operator activated="true" class="select_attributes" compatibility="7.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="136">
<parameter key="attribute_filter_type" value="value_type"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="nominal"/>
<operator activated="true" class="generate_id" compatibility="7.3.001" expanded="true" height="82" name="Generate ID" width="90" x="380" y="85">
<parameter key="create_nominal_ids" value="true"/>
<parameter key="offset" value="0"/>
<operator activated="true" class="loop_parameters" compatibility="7.3.001" expanded="true" height="103" name="Loop Parameters" width="90" x="514" y="136">
<list key="parameters">
<parameter key="Clustering.k" value="[2.0;100.0;10;linear]"/>
</list>
<parameter key="error_handling" value="fail on error"/>
<parameter key="synchronize" value="false"/>
<operator activated="true" class="set_role" compatibility="7.3.001" expanded="true" height="82" name="Set Role (4)" width="90" x="179" y="34">
<parameter key="attribute_name" value="id"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="7.3.001" expanded="true" height="145" name="Cross Validation" width="90" x="380" y="34">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="10"/>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="k_means" compatibility="7.3.001" expanded="true" height="82" name="Clustering" width="90" x="112" y="34">
<parameter key="add_cluster_attribute" value="true"/>
<parameter key="add_as_label" value="false"/>
<parameter key="remove_unlabeled" value="false"/>
<parameter key="k" value="2"/>
<parameter key="max_runs" value="10"/>
<parameter key="determine_good_start_values" value="false"/>
<parameter key="measure_types" value="BregmanDivergences"/>
<parameter key="mixed_measure" value="MixedEuclideanDistance"/>
<parameter key="nominal_measure" value="NominalDistance"/>
<parameter key="numerical_measure" value="EuclideanDistance"/>
<parameter key="divergence" value="SquaredEuclideanDistance"/>
<parameter key="kernel_type" value="radial"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_degree" value="3.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<parameter key="max_optimization_steps" value="100"/>
<connect from_port="training set" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.3.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
<parameter key="create_view" value="false"/>
<operator activated="true" class="performance" compatibility="7.3.001" expanded="true" height="82" name="Performance (2)" width="90" x="179" y="34">
<parameter key="use_example_weights" value="true"/>
<operator activated="true" class="performance_to_data" compatibility="7.3.001" expanded="true" height="82" name="Performance to Data" width="90" x="112" y="391"/>
<operator activated="true" class="write_csv" compatibility="7.3.001" expanded="true" height="82" name="Write CSV" width="90" x="179" y="238">
<parameter key="csv_file" value="C:\Users\Damiano\Documents\risultati.csv"/>
<parameter key="column_separator" value=";"/>
<parameter key="write_attribute_names" value="true"/>
<parameter key="quote_nominal_values" value="true"/>
<parameter key="format_date_attributes" value="true"/>
<parameter key="append_to_file" value="false"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_op="Performance to Data" to_port="performance vector"/>
<connect from_op="Performance to Data" from_port="example set" to_op="Write CSV" to_port="input"/>
<connect from_op="Performance to Data" from_port="performance vector" to_port="performance 1"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Set Role (4)" to_port="example set input"/>
<connect from_op="Set Role (4)" from_port="example set output" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="example set" to_port="result 2"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<operator activated="false" class="set_role" compatibility="7.3.001" expanded="true" height="82" name="Set Role" width="90" x="45" y="391">
<parameter key="attribute_name" value="traceId"/>
<connect from_port="file object" to_op="Read CSV" to_port="file"/>
<connect from_op="Read CSV" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Loop Parameters" to_port="input 1"/>
<connect from_op="Loop Parameters" from_port="result 1" to_port="out 1"/>
<portSpacing port="source_file object" spacing="0"/>
</process>
<connect from_op="Loop Files" from_port="out 1" to_port="result 1"/>
</process>
</process>
