Write Database
User: "mengkoon007"
New Altair Community Member
Updated by Jocelyn
Can someone kindly advise on the "Overwrite mode" in write database?
I am trying to read data from original database, and apply processes onto it, then the output will to write to another database (db1).
Initial record in original db = 1600 records
Initial write to db1 = 1600 records
When the subsequent write trigger, how will the record in db1 updated based on the overwrite mode?
none => It will add again all the records in the original db to db1, so there will be duplicate of records?
overwrite first, append then =>
overwrite =>
append =>
Overwite, how does it checks which record in db1 to overwrite?
append, how does it checks which record should be appended into db1?
Is any of the 4 modes that actually delete all the data in db1 and add again all the data from original data?
1 - 1 of 11
    User: "Thomas_Ott"
    Accepted Answer
    "Overwrite" just overwrites everything.  "Append" just adds rows without overwriting. "Overwrite then Append" will overwrite first and then start appending. For example, if you had 100 rows written, the new data will overwrite the first 100 rows and then start appending.
