Hi All,
I'm using the Rapid Miner Version 5.3 and I would like to install the Extension for Text Processing.
How does that work?
Thanks a lot in advance for your help
Kind regards
Jens
ok, thank you.
If I instal version 7, will then the version 5.3 automatically be overwritten or can I use two versions parallel?
I'm not sure, it's been a long time since I had v5.3 on my machine. I think the structure of where extensions and processes are stored changed somewhere after v5.3.
