File source as input for custom operator in Rapidminer
User: "kamal_pradhan"
New Altair Community Member
Updated by Jocelyn
i am trying to build a custom operator using the extension template available in github. i want my operator take file as an input and give example set as output. i am also using read document operator for getting the file input and using the output as an input for my operator. i have used the following code to achieve
        FileObject fileSet = exampleSetInput.getData(FileObject.class);
but  i get the following error when i run the operator
SEVERE: Process failed: Wrong input of type 'Document' at port 'example set'. Expected type 'File'.
can anybody help on how to use file source in input port of the operator ?
1 - 1 of 11
    User: "land"
    Accepted Answer
    the problem is not in your code but in the way how you connect operators:
    If you use Read Document, you will create an Object of type Document, while your operator expects a FileObject. This you can produce with a Open File operator...
    Greetings,
     Sebastian
