What is the difference between Freeze and Tied contact except DOF selection in Tied?
Whether in freeze contact , if gap exist between master and slave say 0.6 mm , the contact will be enabled /detected only when slave touches the master ? Until then both master and slave are not integral ( seperate parts) . Once gap is closed, the parts will not seperate.
Whereas in Tied contact , both the parts are integral before the part closes its gap if srchdis = 0.6 given. If srchdis not given , the tied contact will not be established initially.
Is my understanding correct ? kindly suggest difference between freeze and Tied contact.
