Hi, is it possible to run a process with macro values?
In the studio flow I am able to use macros to decide which branches should be executed, eg if a given macro value is 0 it means the whole flow needs to be executed, if it is 1 it means the incremental flow needs to be executed.
On the server part however I can find no way to send this value (so 0 or 1) so it makes the whole logic pretty useless. This looks to me like a very basic thing so I am probably overlooking something. I can see some macro binding options in services, but I do not need an output, just a process to run with a give macro value.
Is this possible ?
