Read Document Error & Skipping Over Errors
I get the following error from the Read Document operator (inside Loop Examples after Read Excel with the input URLs). It stops after successully reading several hundred records. I have a log that tells me where the process stops, but do not see anything obviously wrong with the input URL.
Any thoughts on the possible cause? And is there a way to skip past any troublesome input URLs rather than stopping the process with no output?
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="7.3.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34">
<parameter key="excel_file" value="/Users/carl/Documents/SD PDFs.xlsx"/>
<parameter key="imported_cell_range" value="A"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="locale" value="English (United Kingdom)"/>
<parameter key="0" value="SvceDef Link.true.file_path.attribute"/>
</list>
<operator activated="true" class="loop_examples" compatibility="7.3.000" expanded="true" height="103" name="Loop Examples" width="90" x="179" y="34">
<operator activated="true" class="extract_macro" compatibility="7.3.000" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="136">
<parameter key="macro" value="GetURL"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="SvceDef Link"/>
<parameter key="example_index" value="%{example}"/>
<list key="additional_macros"/>
<operator activated="true" class="log" compatibility="7.3.000" expanded="true" height="82" name="Log" width="90" x="179" y="136">
<parameter key="filename" value="/Users/carl/Documents/Log.log"/>
<list key="log">
<parameter key="Log" value="operator.Extract Macro.value.applycount"/>
</list>
<operator activated="true" class="open_file" compatibility="7.3.000" expanded="true" height="68" name="Open File" width="90" x="246" y="34">
<parameter key="resource_type" value="URL"/>
<parameter key="url" value="%{GetURL}"/>
<operator activated="true" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document" width="90" x="380" y="34">
<parameter key="content_type" value="pdf"/>
<parameter key="encoding" value="UTF-8"/>
<operator activated="true" class="text:extract_information" compatibility="7.3.000" expanded="true" height="68" name="Extract Information" width="90" x="514" y="34">
<parameter key="query_type" value="Regular Expression"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries">
<parameter key="Ark" value="[Cc]rown [Hh]osting|Ark Data Cent[re|er]s?|Cody Park|[sS]kyscape|Spring Park"/>
<parameter key="Mainframe" value="Mm]ainframe"/>
</list>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<operator activated="true" class="text:documents_to_data" compatibility="7.3.000" expanded="true" height="82" name="Documents to Data" width="90" x="648" y="34">
<parameter key="text_attribute" value="OriginalText"/>
<operator activated="true" class="generate_attributes" compatibility="7.3.000" expanded="true" height="82" name="Generate Attributes" width="90" x="782" y="34">
<parameter key="URL" value="%{GetURL}"/>
</list>
<connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Log" to_port="through 1"/>
<connect from_op="Open File" from_port="file" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Extract Information" to_port="document"/>
<connect from_op="Extract Information" from_port="document" to_op="Documents to Data" to_port="documents 1"/>
<connect from_op="Documents to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="append" compatibility="7.3.000" expanded="true" height="82" name="Append" width="90" x="313" y="34"/>
<operator activated="true" class="select_attributes" compatibility="7.3.000" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="34">
<parameter key="attribute" value="Text"/>
<parameter key="attributes" value="URL|Ark|Mainframe"/>
<operator activated="true" class="filter_examples" compatibility="7.3.000" expanded="true" height="103" name="Filter Examples" width="90" x="581" y="34">
<list key="filters_list">
<parameter key="filters_entry_key" value="Ark.is_not_missing."/>
<parameter key="filters_entry_key" value="Mainframe.is_not_missing."/>
</list>
<parameter key="filters_logic_and" value="false"/>
<operator activated="true" class="order_attributes" compatibility="7.3.000" expanded="true" height="82" name="Reorder Attributes" width="90" x="715" y="34">
<parameter key="attribute_ordering" value="URL|Mainframe|Ark"/>
<operator activated="true" class="write_excel" compatibility="7.3.000" expanded="true" height="82" name="Write Excel" width="90" x="849" y="34">
<parameter key="excel_file" value="/Users/carl/Documents/Service Definition Matches.xlsx"/>
<connect from_port="input 1" to_op="Read Excel" to_port="file"/>
<connect from_op="Read Excel" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/>
<connect from_op="Reorder Attributes" from_port="example set output" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_port="result 1"/>
