I've got a my first RM personal-learning process working, but it oddly gives me a different answer each time I run it.
If I store the data after Step1 and re-run Step2, it gives the same answer each time, but a slightly wrong answer. If I re-run Steps1&2, then I get different results each time, even though I can verify directly that the source site has not changed.
So not sure if it's a bug, or if I've introduced an error somewhere in my process. I've attached my files in the hope that someone may be able to spot something.
