Hi all,
After installing HyperMesh 2020.1,The temporary node does not always show up yellow,How can I fix this?The temporary node is black when zoomed out of the screen and white when zoomed in. See attached image.
Thanks and regards.
Hello Tom,
Please refer to the page below and delete the temporary files. If HyperMesh behaves or has strange graphics, try this first.
https://community.altair.com/community?id=community_question&sys_id=915684f61b2bd0908017dc61ec4bcb46
If there is no improvement in the above, please refer to the following link to verify that you are using the appropriate graphic board.
https://help.altair.com/hwdesktop/altair_help/topics/getting_started/hw_recommendation_certifications_intro_r.htm
If your graphics card is on the list, please update your graphics driver to the latest version.
Drivers should be available for download from AMD or NVIDIA web pages.
Hello Tom, Please refer to the page below and delete the temporary files. If HyperMesh behaves or has strange graphics, try this first. https://community.altair.com/community?id=community_question&sys_id=915684f61b2bd0908017dc61ec4bcb46 If there is no improvement in the above, please refer to the following link to verify that you are using the appropriate graphic board. https://help.altair.com/hwdesktop/altair_help/topics/getting_started/hw_recommendation_certifications_intro_r.htm If your graphics card is on the list, please update your graphics driver to the latest version. Drivers should be available for download from AMD or NVIDIA web pages.
Thanks for the reply.It seems the cause was the GPU. It was not on the list and it was about to break...I got a new GPU and it's cured.
