What is Generate Attribute Function Set naming convention
jeremy
jeremy New Altair Community Member
I am using the attribute generate function set operator. With 10 input attributes I rapidly obtain many new attributes with names of the form gensymxxx. What is the naming convention for these so that I can decipher them and replace the names with something clearer.
Best Answer
  • Telcontar120
    Telcontar120 New Altair Community Member
    Answer ✓
    You can also use the "Rename by Constructions" to automatically rename the attributes you created to their construction values, if that is what you want (rather than doing it manually, as Andrew's method would require).
  • Andrew
    Andrew New Altair Community Member
    Hello
    On the statistics view, you can right click at the top of summary table and toggle the construction value to yield this information. It's well hidden!
    regards
    Andrew
  • Telcontar120
    Answer ✓
Welcome!
Welcome!
