I have some text files to import to Rapid Miner. For samples:
1. I have a raw text file
- Total record: 1408866
- Column/Attribute: 71
* After importing the file into RapidMiner
- Total record: 148773 (missing 93 records)
2. I have another text file
- Total record: 287147
- Column/Attribute: 269
- Total record: 287109 (missing 38 records)
- Column/Attribute: 35
Then I was trying to re-import the file and uncheck "Skip comments". The first file remained the same, the second file showed the exact record but only 265 attributes.
Is there any problem with the importing feature? How can I get full rows/attributes always from the file?
Thank you.
Ut
