Hi everyone!
In my work, I have to run a customer segmentation for each store. At the begining, I was doing one segmentation by one but now I did a new version with a Loop Process. Now I get all the results at once.
My problem is that I don´t get the same results that I used to have on my first version. Nevertheless, when I set the "use local random seed" and set the value "local random seed" to 1992 on both process (the default one), the results are the same.
I would like to know if there is a way to get the internal seed number that Rapidminer uses. I would like to replicate the results on my new process. I know that it isn't the default 1992 because the results change.
Thanks a lot!
