FP Growth Stack Overflow Error
batstache611
batstache611 New Altair Community Member
I'm text mining on about 50 odd articles about (advanced) manufacturing and wish to see what kinds of words pop up in frequent combination with each other by using the FP Growth operator however it returns a stack overflow error. I'm using -
Process Documents from FIles (transform cases -> tokenize -> filter stopwords -> filter tokens by length) --> Numerical To Binominal --> FP growth.
For generating the word vector, I've chosen binary term occurences as the metric and for min support on the FP Growth operator, I've kept that at 0.1 (I've tried different values but still get the same error).
Is this a bug that I've encountered? Or am I making a silly mistake somewhere? Any and every help is appreciated. Thank you.
Welcome!
  • MartinLiebig
    MartinLiebig
    Dear batstache611,
    welcome to the RapidMiner Community.
    This looks strange to me. I do not see any obvious problem. Is there a chance that you share process and data? Feel free to contact me via PM or email ( mschmitz at rapidminer .com)
    ~Martin
  • hosmy008
    hosmy008 New Altair Community Member
    I have the same problem. I have shared the entire message i receive and a photo of the error.
    Reza
  • Thomas_Ott
    Hi everyone,
    Of the top of my head, the process looks correct so it leads me to believe there's a parameter setting that's causing your issues.
    If you're using the Num>Binom operator you should check out what Min and Max parameters.  If you used a Word Vector setting of TF-IDF, you'll have to set the max value in the Num>Binom operator it to assign a true value.  Another way is to set the Word Vector to to Binanary occurances and then Num>Binomal operator max value to 1.0
    Give that a try.
Welcome!
Welcome!
