"join operator problem..."
User: "Fred12"
New Altair Community Member
Updated by Jocelyn
hi,
I used join operator to join 4 outlier detection columns to my dataset, however, only 2 are showing up, here is my code:
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.2.001" expanded="true" height="68" name="Retrieve Master3Klassen_nominal" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Marc/data/Master3Klassen_nominal"/>
<operator activated="true" class="generate_id" compatibility="7.2.001" expanded="true" height="82" name="Generate ID" width="90" x="112" y="238"/>
<operator activated="true" class="normalize" compatibility="7.2.001" expanded="true" height="103" name="Normalize" width="90" x="246" y="187"/>
<operator activated="true" class="multiply" compatibility="7.2.001" expanded="true" height="145" name="Multiply" width="90" x="380" y="85"/>
<operator activated="true" class="anomalydetection:One-Class LIBSVM Anomaly Score" compatibility="2.3.002" expanded="true" height="82" name="One-Class LIBSVM Anomaly Score" width="90" x="313" y="340"/>
<operator activated="true" class="anomalydetection:k-NN Global Anomaly Score" compatibility="2.3.002" expanded="true" height="103" name="k-NN Global Anomaly Score (2)" width="90" x="715" y="85">
<parameter key="k" value="1"/>
<parameter key="use k-th neighbor distance only (no average)" value="true"/>
<parameter key="measure_types" value="NumericalMeasures"/>
<parameter key="numerical_measure" value="CamberraDistance"/>
<parameter key="parallelize evaluation process" value="true"/>
<operator activated="true" class="rename" compatibility="7.2.001" expanded="true" height="82" name="Rename" width="90" x="916" y="85">
<parameter key="old_name" value="outlier"/>
<parameter key="new_name" value="k-NN_outlier"/>
<list key="rename_additional_attributes"/>
<operator activated="true" class="rename" compatibility="7.2.001" expanded="true" height="82" name="Rename (4)" width="90" x="447" y="391">
<parameter key="new_name" value="LIBSVM_outlier"/>
<operator activated="false" class="set_role" compatibility="7.2.001" expanded="true" height="82" name="Set Role" width="90" x="1117" y="85">
<parameter key="attribute_name" value="k-NN_outlier"/>
<operator activated="true" class="set_role" compatibility="7.2.001" expanded="true" height="82" name="Set Role (3)" width="90" x="581" y="391">
<parameter key="attribute_name" value="LIBSVM_outlier"/>
<operator activated="true" class="anomalydetection:Local Outlier Factor (LOF)" compatibility="2.3.002" expanded="true" height="103" name="Local Outlier Factor (LOF)" width="90" x="581" y="238">
<parameter key="k_min (MinPtsLB)" value="1"/>
<parameter key="k_max (MinPtsUB)" value="30"/>
<operator activated="true" class="anomalydetection:Connectivity-Based Outlier Factor (COF)" compatibility="2.3.002" expanded="true" height="103" name="Connectivity-Based Outlier Factor (COF)" width="90" x="313" y="544">
<operator activated="true" class="rename" compatibility="7.2.001" expanded="true" height="82" name="Rename (2)" width="90" x="782" y="187">
<parameter key="new_name" value="LOF_outlier"/>
<operator activated="true" class="rename" compatibility="7.2.001" expanded="true" height="82" name="Rename (3)" width="90" x="447" y="544">
<parameter key="new_name" value="COF_outlier"/>
<operator activated="true" class="set_role" compatibility="7.2.001" expanded="true" height="82" name="Set Role (2)" width="90" x="983" y="187">
<parameter key="attribute_name" value="LOF_outlier"/>
<operator activated="true" class="join" compatibility="7.2.001" expanded="true" height="82" name="Join" width="90" x="1184" y="238">
<parameter key="remove_double_attributes" value="false"/>
<list key="key_attributes"/>
<parameter key="keep_both_join_attributes" value="true"/>
<operator activated="true" class="set_role" compatibility="7.2.001" expanded="true" height="82" name="Set Role (4)" width="90" x="581" y="544">
<parameter key="attribute_name" value="COF_outlier"/>
<operator activated="true" class="join" compatibility="7.2.001" expanded="true" height="82" name="Join (2)" width="90" x="983" y="493">
<operator activated="true" class="join" compatibility="7.2.001" expanded="true" height="82" name="Join (3)" width="90" x="1117" y="391">
<connect from_op="Retrieve Master3Klassen_nominal" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Local Outlier Factor (LOF)" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_op="One-Class LIBSVM Anomaly Score" to_port="example set"/>
<connect from_op="Multiply" from_port="output 3" to_op="k-NN Global Anomaly Score (2)" to_port="example set"/>
<connect from_op="Multiply" from_port="output 4" to_op="Connectivity-Based Outlier Factor (COF)" to_port="example set"/>
<connect from_op="One-Class LIBSVM Anomaly Score" from_port="example set" to_op="Rename (4)" to_port="example set input"/>
<connect from_op="k-NN Global Anomaly Score (2)" from_port="example set" to_op="Rename" to_port="example set input"/>
<connect from_op="k-NN Global Anomaly Score (2)" from_port="model" to_port="result 1"/>
<connect from_op="Rename" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Rename (4)" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/>
<connect from_op="Set Role (3)" from_port="example set output" to_op="Join (2)" to_port="left"/>
<connect from_op="Local Outlier Factor (LOF)" from_port="example set" to_op="Rename (2)" to_port="example set input"/>
<connect from_op="Connectivity-Based Outlier Factor (COF)" from_port="example set" to_op="Rename (3)" to_port="example set input"/>
<connect from_op="Rename (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Rename (3)" from_port="example set output" to_op="Set Role (4)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Join" from_port="join" to_op="Join (3)" to_port="left"/>
<connect from_op="Set Role (4)" from_port="example set output" to_op="Join (2)" to_port="right"/>
<connect from_op="Join (2)" from_port="join" to_op="Join (3)" to_port="right"/>
<connect from_op="Join (3)" from_port="join" to_port="result 2"/>
</process>
</process>
I could not resolve what the problem is..
1 - 1 of 11
    User: "MariusHelf"
    Hey, are you sure the attributes are gone? They should still be in the data (but they may change position, i.e., they are not necessarily at the top/left of the data set.
    Cheers,
    Marius
