after upgrading to RM 7.2 I'm trying to use the Tableau Data Writer but it fails every time with this stack trace
Exception: java.lang.NoClassDefFoundError
Message: Could not initialize class com.tableausoftware.DataExtract.Collation
Stack trace:
com.rapidminer.extension.tableau.operator.io.TableauWriter.extractData(TableauWriter.java:127)
com.rapidminer.extension.tableau.operator.io.TableauWriter.write(TableauWriter.java:77)
com.rapidminer.extension.tableau.operator.io.TableauWriter.write(TableauWriter.java:36)
com.rapidminer.operator.io.AbstractWriter.doWork(AbstractWriter.java:68)
com.rapidminer.operator.Operator.execute(Operator.java:1021)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:76)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:798)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:392)
com.rapidminer.Process.run(Process.java:1179)
com.rapidminer.Process.run(Process.java:1081)
com.rapidminer.Process.run(Process.java:1034)
com.rapidminer.Process.run(Process.java:1029)
com.rapidminer.Process.run(Process.java:1019)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
I've downloaded the Tableau Extract API (64 bit, same as RM) and extracted it to disk. I've also added the \bin to my PATH so it should be working but does not.
