Hi, I wanted to connect to my SQL databases using the new RM7.2, but get a time out on any connection that I make.
To make clear :
-> The same connections work perfect using RM5 so the settings are expected to be correct (tripple checked that one)
-> I have the problem with connections to different SQL servers, using different credentials (and all of them work using RM5)
I'm running the 64bit version of RM72, and have Java 8 installed. Is there anything else I need to install (drivers?) to get a connection to SQL servers, or is it supposed to work out of the box ?
