I am trying to call a url to get a JSON response. I am using Enrich Data with Webservice. This is convinient since there are settings available to pull out the specific values through the jsonpath.
The problem that I am having is that the url that I am calling is received from upstream and different everytime. I need to add authentication parameters to the url as well. To do this I was thinking of encoding the url and then encode my authentication parameters. When I encode a url path the output converts all symbols such as a colon to hex values. For example "http://abc.com" turns to "http%3A%2F%2Fabc.com". Enrich Data with Webservices then throws an error. Is there a way to encode a full url path?
The other method to do this is to use Get Pages, but I have another issue with that.
Below is a simplified process of the issue.
<process version="7.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.1.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data_user_specification" compatibility="7.1.001" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="34">
<list key="attribute_values">
<parameter key="xUrl" value=""https://content.guardianapis.com/sport/2016/aug/02/lizzie-armitstead-missed-tests-cycling-rochelle-gilmore""/>
</list>
<operator activated="true" breakpoints="after" class="web:encode_urls" compatibility="7.1.001" expanded="true" height="82" name="Encode URLs (2)" width="90" x="313" y="34">
<parameter key="url_attribute" value="xUrl"/>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.1.001" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="514" y="34">
<parameter key="query_type" value="JsonPath"/>
<list key="string_machting_queries"/>
<parameter key="attribute_type" value="Nominal"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<parameter key="ignore_CDATA" value="true"/>
<parameter key="assume_html" value="true"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<parameter key="request_method" value="GET"/>
<parameter key="url" value="<%xUrl%>"/>
<parameter key="delay" value="0"/>
<list key="request_properties"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Encode URLs (2)" to_port="example set input"/>
<connect from_op="Encode URLs (2)" from_port="example set output" to_op="Enrich Data by Webservice" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_port="result 1"/>
</process>
</process>
