I just updated from 7.1 to 7.2. Now when I open the program I'm getting a "JNI error has occurred...". How do I fix that?
Thanks,
Shawn
Had something similar, and it turned out I did not have java 8 installed. Installed J8, reinstalled RM7.2 and worked fine then
I'm pretty sure the issue is that my Java version is 6 and I need to get 8 in order for the RapidMiner 7.2 upgrade to work properly.
What version of Java are you using?
Sometimes its best to do a clean install. Check out this link: http://community.rapidminer.com/t5/RapidMiner-Studio/RapidMiner-not-loading-past-the-blank-process-screen/m-p/32444#U32444
I have similar error when I updated RapidMiner. I had Java 1.8 installed. Getting JNI error after update.
Thanks
hello @aksingh - what exact versions of RapidMiner and Java are you running? OS?
Scott
