Questions about customer clustering/segmentation
User: "Franzi"
New Altair Community Member
Updated by Jocelyn
I’m new to rapidminer, I did all the tutorials, but when I try my own cases, its a bit difficult to find the rigth operators and parameters.
I want to cluster my customers (CustomerID) in three groups based on their transactions.
Transactionsattributes are:
Date of transaction (datatype: date)
Value of transaction (datatype: integer)
Number of transactions (datatype: integer)
I would like to give the customers with following features a higher rate (weight)
  • more than one transactions
  • with a higher transactionsvalue than average
  • recent transactions (i.e. transactions in the last month)
Is their any possibilty to create a process in rapidminer, that reflect my requirements?
Which operator would be best for that use case?
Thanks for your help in advance and sorry for my poor english!
Franzi
1 - 1 of 11
    User: "YYH"
    Accepted Answer
    'Generate Attribute' operator is your good friend, to achieve your goal 'to give the customers with following features a higher rate (weight)'
    you can create several indicator attributes, for instance, to tag the customers who has any more than one transactions,
    attribute name                                function expression
    AnyTransaction                             if(Number of transactions>1, 1,0)
    You can refer to the tutorial process for Generate Attribute, and get inspired by the example function expressions.
    Happy RapidMining!
