Dear all,
I have installed R extension in my rapidminer, but when I try to run a simple example code I recieve "Process failed. Script terminated abnormaly" error message.
This is the log from pop-up window:
- Exception: com.rapidminer.operator.OperatorException
- Message: Script terminated abnormally.
- Stack trace:
- com.rapidminer.operator.scripting.AbstractScriptRunner.run(AbstractScriptRunner.java:162)
- com.rapidminer.operator.scripting.AbstractScriptingLanguageOperator.doWork(AbstractScriptingLanguageOperator.java:90)
- com.rapidminer.operator.scripting.r.RScriptingOperator.doWork(RScriptingOperator.java:73)
- com.rapidminer.operator.Operator.execute(Operator.java:1002)
- com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:50)
- com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:798)
- com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:392)
- com.rapidminer.Process.run(Process.java:1071)
- com.rapidminer.Process.run(Process.java:973)
- com.rapidminer.Process.run(Process.java:926)
- com.rapidminer.Process.run(Process.java:921)
- com.rapidminer.Process.run(Process.java:911)
- com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
I have RM 32 bit, R-3-1-2 (32 bit) and the java path also refers to 32 bit av java.
JAVA_HOME= C:\Program Files (x86)\RapidMiner\RapidMiner Studio\jre
R_HOME= C:\Program Files\R\R-3.1.2\bin\i386
I get the same error with
JAVA_HOME= C:\Program Files (x86)\Java\jre1.8.0_91\
I appreciate your help.
Mahdi
