I am having some severe problems with random crashes. I added a loop parameters operator to incrementally increase the population size of an optimize selection (evolutionary,parallel) operator. Nothing extreme, just nine increments from 5-50 and I am using six threads. There is 50% available memory while running the process so memory is not the issue.
The problem is that sometimes it works fine and then other times it crashes with an error. I don't get an error if I run the process without looping parameters. Here is a snapshot of the exception if that helps:-
Kind regards,
Alex
Exception: java.util.ConcurrentModificationException
Message: null
Stack trace:
java.util.LinkedList$ListItr.checkForComodification(LinkedList.java:966)
java.util.LinkedList$ListItr.next(LinkedList.java:888)
java.util.AbstractList.hashCode(AbstractList.java:540)
com.rapidminer.example.SimpleAttributes.hashCode(SimpleAttributes.java:84)
com.rapidminer.example.set.AbstractExampleSet.hashCode(AbstractExampleSet.java:366)
com.rapidminer.example.set.SplittedExampleSet.hashCode(SplittedExampleSet.java:174)
com.rapidminer.tools.ReferenceCache$TransparentWeakReference.(ReferenceCache.java:139)
com.rapidminer.tools.ReferenceCache$TransparentWeakReference.(ReferenceCache.java:131)
com.rapidminer.tools.ReferenceCache$Reference.(ReferenceCache.java:71)
com.rapidminer.tools.ReferenceCache$Reference.(ReferenceCache.java:59)
com.rapidminer.tools.ReferenceCache.newReference(ReferenceCache.java:204)
com.rapidminer.operator.ports.impl.AbstractPort.setData(AbstractPort.java:72)
com.rapidminer.operator.ports.impl.OutputPortImpl.deliver(OutputPortImpl.java:56)
com.rapidminer.operator.ModelApplier.doWork(ModelApplier.java:112)
com.rapidminer.operator.Operator.execute(Operator.java:1002)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:50)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:798)
com.rapidminer.operator.validation.ValidationChain.executeEvaluator(ValidationChain.java:234)
com.rapidminer.operator.validation.ValidationChain.evaluate(ValidationChain.java:335)
com.rapidminer.operator.validation.SlidingWindowValidation.estimatePerformance(SlidingWindowValidation.java:141)
com.rapidminer.operator.validation.ValidationChain.doWork(ValidationChain.java:285)
com.rapidminer.operator.executor.ParallelUnitExecutor$OperatorExecution.run(ParallelUnitExecutor.java:59)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
java.lang.Thread.run(Thread.java:745)
