I have a vectorset containing a few thousand attributes, and want to work with amples for testing purposes. Easy enough to get the sampleset, but I also get the full attributeset while I am only interested in the ones that are applicable for the sample. What is the easiest way to remove all irrelevant attributes?
example :
value1 - true - true -false - true
value2 - true - false -false -false
value3 - false - true -false - true
In this oversimplied example it would mean I like to skip the 3d attribute, as it is always false. What is the fastes way to achieve this (on a much bigger set)?
