Error in date format
hi.
i am working with the data containing date and and text processing .
separately these processes are working well. but after joining these i get the error message for the variable "current" in which i am using date_now() to get the system date. but later i took date difference (date-of-post and current) by converting it into date to numerical.
the process is as follows:
THE CSV file consists of :
DateOfPost- polynomial( e.g. 12/10/2006)
sentimentText- text(e.g. "i have bought a new car last week.it is very good")
id- integer(e.g. 1,2,3,4....................)
XML file is as follows:
<code>
<process version="6.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="6.3.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="c2'07"/>
<operator activated="true" class="filter_examples" compatibility="6.3.000" expanded="true" height="94" name="Filter Examples" width="90" x="112" y="120">
<list key="filters_list">
<parameter key="filters_entry_key" value="id.eq.182"/>
<parameter key="filters_entry_key" value="id.eq.319"/>
<parameter key="filters_entry_key" value="id.eq.330"/>
<parameter key="filters_entry_key" value="id.eq.345"/>
<parameter key="filters_entry_key" value="id.eq.582"/>
<parameter key="filters_entry_key" value="id.eq.733"/>
<parameter key="filters_entry_key" value="id.eq.1927"/>
<parameter key="filters_entry_key" value="id.eq.1987"/>
<parameter key="filters_entry_key" value="id.eq.2269"/>
<parameter key="filters_entry_key" value="id.eq.2312"/>
</list>
<operator activated="true" class="wordnet:open_wordnet_dictionary" compatibility="5.3.000" expanded="true" height="60" name="Open WordNet Dictionary" width="90" x="179" y="210">
<parameter key="directory" value="/home/sukh/Documents/WordNet-3.0/dict"/>
<operator activated="true" class="remember" compatibility="6.3.000" expanded="true" height="60" name="Remember" width="90" x="246" y="255">
<parameter key="name" value="wordnet"/>
<parameter key="io_object" value="WordnetDictionary"/>
<operator activated="true" class="subprocess" compatibility="6.3.000" expanded="true" height="76" name="Subprocess" width="90" x="313" y="120">
<portSpacing port="source_in 2" spacing="0"/>
</process>
<operator activated="true" class="multiply" compatibility="6.3.000" expanded="true" height="94" name="Multiply" width="90" x="45" y="210"/>
<operator activated="true" class="nominal_to_date" compatibility="6.3.000" expanded="true" height="76" name="Nominal to Date" width="90" x="45" y="435">
<parameter key="attribute_name" value="DateOfPost"/>
<parameter key="date_format" value="MM/dd/yyyy"/>
<operator activated="true" class="date_to_numerical" compatibility="6.3.000" expanded="true" height="76" name="Date to Numerical (2)" width="90" x="179" y="435">
<parameter key="time_unit" value="day"/>
<parameter key="day_relative_to" value="epoch"/>
<operator activated="true" class="generate_attributes" compatibility="6.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="345">
<parameter key="current" value="date_now()"/>
<parameter key="current1" value="date_parse_custom(current,"mm/dd/yyyy"))"/>
</list>
<operator activated="true" class="date_to_numerical" compatibility="6.3.000" expanded="true" height="76" name="Date to Numerical" width="90" x="313" y="435">
<parameter key="attribute_name" value="current"/>
<operator activated="true" class="generate_attributes" compatibility="6.3.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="380" y="300">
<parameter key="current" value="current-2034"/>
<parameter key="Dtag" value="current-DateOfPost"/>
</list>
<operator activated="true" class="discretize_by_user_specification" compatibility="6.3.000" expanded="true" height="94" name="Discretize (2)" width="90" x="447" y="390">
<parameter key="attribute" value="Dtag"/>
<list key="classes">
<parameter key="present" value="375.0"/>
<parameter key="past" value="Infinity"/>
</list>
<operator activated="true" class="text:process_document_from_data" compatibility="6.1.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="30">
<parameter key="keep_text" value="true"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="6.1.000" expanded="true" height="60" name="Tokenize" width="90" x="112" y="30"/>
<operator activated="true" class="recall" compatibility="6.3.000" expanded="true" height="60" name="Recall" width="90" x="45" y="120">
<parameter key="remove_from_store" value="false"/>
<operator activated="true" class="wordnet:find_sentiment_wordnet" compatibility="5.3.000" expanded="true" height="76" name="Extract Sentiment (English)" width="90" x="246" y="75"/>
<operator activated="true" class="text:stem_dictionary" compatibility="6.1.000" expanded="true" height="76" name="Stem (Dictionary)" width="90" x="450" y="30">
<parameter key="file" value="/home/sukh/Desktop/stemhindi"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Extract Sentiment (English)" to_port="document"/>
<connect from_op="Recall" from_port="result" to_op="Extract Sentiment (English)" to_port="dictionary"/>
<connect from_op="Extract Sentiment (English)" from_port="document" to_op="Stem (Dictionary)" to_port="document"/>
<connect from_op="Stem (Dictionary)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="generate_attributes" compatibility="6.3.000" expanded="true" height="76" name="Generate Attributes (3)" width="90" x="380" y="30">
<parameter key="present" value="(length(text)-length(replaceAll(text,"present","")))/length("present")"/>
<parameter key="past" value="(length(text)-length(replaceAll(text,"past","")))/length("past")"/>
<parameter key="future" value="(length(text)-length(replaceAll(text,"future","")))/length("future")"/>
<parameter key="Ttag" value="if(present==max(present,past,future),"present",if(past==max(present,past,future),"past",if(future==max(present,past,future),"future",0)))"/>
</list>
<operator activated="true" class="join" compatibility="6.3.000" expanded="true" height="76" name="Join" width="90" x="514" y="165">
<parameter key="join_type" value="outer"/>
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="id" value="id"/>
</list>
<parameter key="keep_both_join_attributes" value="true"/>
<operator activated="true" class="generate_attributes" compatibility="6.3.000" expanded="true" height="76" name="Generate Attributes (5)" width="90" x="514" y="30">
<parameter key="new1" value="if(Ttag=="present",if(Dtag=="past","past",if(Dtag=="present","present",0)),"z")"/>
<parameter key="new" value="if(Ttag=="past",if(Dtag=="past","past",if(Dtag=="present","past",0)),new1)"/>
<parameter key="Temptag" value="if(Ttag=="future",if(Dtag=="past","past",if(Dtag=="present","future",0)),new)"/>
</list>
<connect from_op="Retrieve" from_port="output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Open WordNet Dictionary" from_port="dictionary" to_op="Remember" to_port="store"/>
<connect from_op="Remember" from_port="stored" to_op="Subprocess" to_port="in 1"/>
<connect from_op="Subprocess" from_port="out 1" to_op="Process Documents from Data" to_port="word list"/>
<connect from_op="Multiply" from_port="output 1" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_op="Nominal to Date" to_port="example set input"/>
<connect from_op="Nominal to Date" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/>
<connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/>
<connect from_op="Date to Numerical" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/>
<connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Discretize (2)" to_port="example set input"/>
<connect from_op="Discretize (2)" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Generate Attributes (3)" to_port="example set input"/>
<connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Join" from_port="join" to_op="Generate Attributes (5)" to_port="example set input"/>
<connect from_op="Generate Attributes (5)" from_port="example set output" to_port="result 1"/>
</process>
</process>
</code>
Kindly help me for the same.
Thanks and Regards:
Sukh
