"[SOLVED]Using PCA with Test Set Getting Error"
I am working on a dataset with large number of attributes(590) and also this dataset has class imbalance problem.It is a binomial classification problem. i am trying to do PCA first and then apply the reduced dataset for cross validation using decision tree. Then i have grouped these two models and applied on the test set. But the rapidminer gives error at the applymodel saying :"The setup does not seem to contain any obvious errors, but you should check the log messages or activate the debug mode in the settings dialog in order to get more information about this problem." when i checked the log the last line :
SEVERE: java.lang.NullPointerException. please help me with that ::) .Here is my xml code:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve semiconductortesting" width="90" x="45" y="255">
<parameter key="repository_entry" value="../data/semiconductor/semiconductortesting"/>
<operator activated="true" class="materialize_data" compatibility="5.3.015" expanded="true" height="76" name="Materialize Data (2)" width="90" x="246" y="255"/>
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve kmedoid_undersampled_data" width="90" x="45" y="30">
<parameter key="repository_entry" value="../data/semiconductor/kmedoid_undersampled_data"/>
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve SMOTE_oversampled_data" width="90" x="45" y="120">
<parameter key="repository_entry" value="../data/semiconductor/SMOTE_oversampled_data"/>
<operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="94" name="Append" width="90" x="179" y="30"/>
<operator activated="true" class="materialize_data" compatibility="5.3.015" expanded="true" height="76" name="Materialize Data" width="90" x="313" y="30"/>
<operator activated="false" class="shuffle" compatibility="5.3.015" expanded="true" height="76" name="Shuffle" width="90" x="983" y="210">
<parameter key="use_local_random_seed" value="true"/>
<parameter key="local_random_seed" value="532"/>
<operator activated="true" class="principal_component_analysis" compatibility="5.3.015" expanded="true" height="94" name="PCA" width="90" x="447" y="30">
<parameter key="number_of_components" value="250"/>
<operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation" width="90" x="581" y="30">
<parameter key="number_of_validations" value="2"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<operator activated="true" class="decision_tree" compatibility="5.3.015" expanded="true" height="76" name="Decision Tree" width="90" x="133" y="30"/>
<connect from_port="training" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="ApplyDEcisiontree" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="5.3.015" expanded="true" height="76" name="trainingperformance (3)" width="90" x="179" y="30"/>
<operator activated="false" class="performance_binominal_classification" compatibility="5.3.015" expanded="true" height="76" name="trainingperformance (2)" width="90" x="112" y="165">
<parameter key="AUC" value="true"/>
<parameter key="f_measure" value="true"/>
<operator activated="false" class="performance_costs" compatibility="5.3.015" expanded="true" height="76" name="trainingcostperformance" width="90" x="246" y="165">
<parameter key="cost_matrix" value="[0.0 4.0;1.0 0.0]"/>
<enumeration key="class_order_definition">
<parameter key="class_name" value="-1.0"/>
<parameter key="class_name" value="1.0"/>
</enumeration>
<operator activated="false" breakpoints="after" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="trainingperformance" width="90" x="380" y="255">
<parameter key="main_criterion" value="accuracy"/>
<parameter key="classification_error" value="true"/>
<parameter key="weighted_mean_recall" value="true"/>
<parameter key="weighted_mean_precision" value="true"/>
<parameter key="root_mean_squared_error" value="true"/>
<list key="class_weights"/>
<connect from_port="model" to_op="ApplyDEcisiontree" to_port="model"/>
<connect from_port="test set" to_op="ApplyDEcisiontree" to_port="unlabelled data"/>
<connect from_op="ApplyDEcisiontree" from_port="labelled data" to_op="trainingperformance (3)" to_port="labelled data"/>
<connect from_op="trainingperformance (3)" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="group_models" compatibility="5.3.015" expanded="true" height="94" name="Group Models" width="90" x="313" y="165"/>
<operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="applyontestdata" width="90" x="447" y="255">
<operator activated="true" class="performance" compatibility="5.3.015" expanded="true" height="76" name="PerformanceTestdata" width="90" x="581" y="210"/>
<connect from_op="Retrieve semiconductortesting" from_port="output" to_op="Materialize Data (2)" to_port="example set input"/>
<connect from_op="Materialize Data (2)" from_port="example set output" to_op="applyontestdata" to_port="unlabelled data"/>
<connect from_op="Retrieve kmedoid_undersampled_data" from_port="output" to_op="Append" to_port="example set 1"/>
<connect from_op="Retrieve SMOTE_oversampled_data" from_port="output" to_op="Append" to_port="example set 2"/>
<connect from_op="Append" from_port="merged set" to_op="Materialize Data" to_port="example set input"/>
<connect from_op="Materialize Data" from_port="example set output" to_op="PCA" to_port="example set input"/>
<connect from_op="PCA" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="PCA" from_port="preprocessing model" to_op="Group Models" to_port="models in 1"/>
<connect from_op="Validation" from_port="model" to_op="Group Models" to_port="models in 2"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
<connect from_op="Group Models" from_port="model out" to_op="applyontestdata" to_port="model"/>
<connect from_op="applyontestdata" from_port="labelled data" to_op="PerformanceTestdata" to_port="labelled data"/>
<connect from_op="PerformanceTestdata" from_port="performance" to_port="result 2"/>
</process>
</process>
1 - 5 of
51
JEdward
New Altair Community Member
Activate debug mode by right clicking in your process window and selecting All Breakpoints (debug) mode. This will help you to identify which operator is causing the problem. Is it before the PCA or after the PCA where the error occurs (for example).
Thanks for that.
What are the differences in attributes between your training & test datasets?
When generated some sample data to test your process it works without an issue for me, but I know that if the features aren't the same for the training & test then it might cause problems when trying to apply the models.
To test this try connecting your original data (training) to the the apply model to see if it still causes errors. If it doesn't then you know you need to match the features on both sides. You could use an operator like 'Superset' to do this, but this will only add the attributes, it's better to delve in and have a look at the two datasets.
Likely it's something really simple like a field stored as polynominal in the training data is numerical in the test data.
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<operator activated="false" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve semiconductortesting" width="90" x="45" y="255">
<operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve kmedoid_undersampled_data" width="90" x="45" y="30">
<operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve SMOTE_oversampled_data" width="90" x="45" y="120">
<operator activated="false" class="shuffle" compatibility="6.4.000" expanded="true" height="76" name="Shuffle" width="90" x="983" y="210">
<operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="94" name="Append" width="90" x="179" y="30"/>
<operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="45" y="210">
<description align="center" color="transparent" colored="false" width="126">This multiply forces sends the training data to be tested rather than the test data.</description>
<operator activated="true" class="materialize_data" compatibility="6.4.000" expanded="true" height="76" name="Materialize Data (2)" width="90" x="179" y="300"/>
<operator activated="true" class="materialize_data" compatibility="6.4.000" expanded="true" height="76" name="Materialize Data" width="90" x="313" y="30"/>
<operator activated="true" class="principal_component_analysis" compatibility="6.4.000" expanded="true" height="94" name="PCA" width="90" x="447" y="30">
<operator activated="true" class="x_validation" compatibility="6.4.000" expanded="true" height="112" name="Validation" width="90" x="581" y="30">
<operator activated="true" class="decision_tree" compatibility="6.4.000" expanded="true" height="76" name="Decision Tree" width="90" x="133" y="30"/>
</process>
<operator activated="true" class="apply_model" compatibility="6.4.000" expanded="true" height="76" name="ApplyDEcisiontree" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="6.4.000" expanded="true" height="76" name="trainingperformance (3)" width="90" x="179" y="30"/>
<operator activated="false" class="performance_binominal_classification" compatibility="6.4.000" expanded="true" height="76" name="trainingperformance (2)" width="90" x="112" y="165">
<operator activated="false" class="performance_costs" compatibility="6.4.000" expanded="true" height="76" name="trainingcostperformance" width="90" x="246" y="165">
</enumeration>
<operator activated="false" breakpoints="after" class="performance_classification" compatibility="6.4.000" expanded="true" height="76" name="trainingperformance" width="90" x="380" y="255">
</process>
<operator activated="true" class="group_models" compatibility="6.4.000" expanded="true" height="94" name="Group Models" width="90" x="313" y="165"/>
<operator activated="true" class="apply_model" compatibility="6.4.000" expanded="true" height="76" name="applyontestdata" width="90" x="447" y="255">
<operator activated="true" class="performance" compatibility="6.4.000" expanded="true" height="76" name="PerformanceTestdata" width="90" x="581" y="210"/>
<connect from_op="Append" from_port="merged set" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Materialize Data" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Materialize Data (2)" to_port="example set input"/>
</process>
</process>
Thanks! Yes this is the problem. i ran it in Rapidminer 6.4 now, and it showed me the problem that some attributes in training and test set mismatch(in type). My dataset has large number of attributes some are set to numerical, some to integer, some to real, and one is nominal label. pls suggest how can i match attribute types in both sets i.e. training and test set. For example, i want all attributes to be of type real(but for label). If i again load dataset in rapidminer do i have to set each attribute manualy? there are alot of them...there must be some other way..sry i am new in this.
