Using this XML I get an error. Somebody any suggestion?
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="radoop:radoop_nest" compatibility="2.1.001" expanded="true" height="112" name="Radoop Nest" width="90" x="46" y="33">
<parameter key="connection" value="cds.analytics.vancis.nl"/>
<operator activated="true" class="radoop:retrieve" compatibility="2.1.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="38">
<parameter key="table" value="zhongheng20150725"/>
<operator activated="true" class="radoop:hive_split_validation" compatibility="2.1.001" expanded="true" height="112" name="Validation" width="90" x="219" y="103">
<operator activated="true" class="radoop:hive_naive_bayes" compatibility="2.1.001" expanded="true" height="76" name="Naive Bayes" width="90" x="51" y="36"/>
<connect from_port="training" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="radoop:apply_prediction" compatibility="2.1.001" expanded="true" height="76" name="Apply Model" width="90" x="45" y="31">
<operator activated="true" class="radoop:hive_performance_binominal" compatibility="2.1.001" expanded="true" height="76" name="Performance" width="90" x="161" y="30">
<parameter key="positive_class" value="N"/>
<parameter key="classification_error" value="true"/>
<parameter key="kappa" value="true"/>
<parameter key="precision" value="true"/>
<parameter key="recall" value="true"/>
<parameter key="lift" value="true"/>
<parameter key="fallout" value="true"/>
<parameter key="f_measure" value="true"/>
<parameter key="false_positive" value="true"/>
<parameter key="false_negative" value="true"/>
<parameter key="true_positive" value="true"/>
<parameter key="true_negative" value="true"/>
<parameter key="sensitivity" value="true"/>
<parameter key="specificity" value="true"/>
<parameter key="youden" value="true"/>
<parameter key="positive_predictive_value" value="true"/>
<parameter key="negative_predictive_value" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Retrieve" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
<portSpacing port="sink_output 4" spacing="0"/>
</process>
<connect from_op="Radoop Nest" from_port="output 1" to_port="result 1"/>
<connect from_op="Radoop Nest" from_port="output 2" to_port="result 2"/>
<connect from_op="Radoop Nest" from_port="output 3" to_port="result 3"/>
</process>
</process>
HiveQL problem (java.sql.SQLException: Error while compiling statement: FAILED: SemanticException [Error 10011]: Line 1:437 Invalid function 'r_esc')
Cheers
Sven
