Hi Krishna,
This is a response to your question here:
https://support.rapidminer.com/customer/en/portal/questions/13036889-generation-of-new-attribute?new=13036889If I understand this correctly you do not begin with two columns of data.
You begin with 1 column (att1) and you want to calculate the value for att2 based on the result of the previous column.
In Excel you might represent this as
30 =A1
40 =A2+(B1/2)
50 =A3+(B2/2)
With the results
30 30
40 55
50 77.5
I RapidMiner you would use the operator Loop Examples to step through each example in order and calculate the result.
Try this example XML and see if it works for you:
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="subprocess" compatibility="6.4.000" expanded="true" height="76" name="Generate Test Data" width="90" x="45" y="30">
<operator activated="true" class="text:create_document" compatibility="6.4.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="30">
<parameter key="text" value="att1 30 40 50 10 20 "/>
<operator activated="true" class="text:write_document" compatibility="6.4.001" expanded="true" height="76" name="Write Document" width="90" x="179" y="30"/>
<connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/>
<connect from_op="Write Document" from_port="file" to_port="out 1"/>
</process>
<description align="center" color="transparent" colored="false" width="126">This is some test data. You would normally swap this out with your own CSV.</description>
<operator activated="true" class="read_csv" compatibility="6.4.000" expanded="true" height="60" name="Read CSV" width="90" x="179" y="30">
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="att1.true.integer.attribute"/>
</list>
<operator activated="true" class="generate_empty_attribute" compatibility="6.4.000" expanded="true" height="76" name="Generate Empty Attribute" width="90" x="313" y="30">
<parameter key="name" value="att2"/>
<description align="center" color="transparent" colored="false" width="126">Here we create a blank attribute called att2. We will begin to populate this in two operators time.</description>
<operator activated="true" class="set_macro" compatibility="6.4.000" expanded="true" height="76" name="Set Macro" width="90" x="447" y="30">
<parameter key="macro" value="att3"/>
<parameter key="value" value="0"/>
<description align="center" color="transparent" colored="false" width="126">This creates the att3 macro and ensures on the first example the value is 0.</description>
<operator activated="true" class="loop_examples" compatibility="6.4.000" expanded="true" height="76" name="Loop Examples" width="90" x="581" y="30">
<operator activated="true" class="extract_macro" compatibility="6.4.000" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="30">
<parameter key="macro" value="att1"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="att1"/>
<parameter key="example_index" value="%{example}"/>
<list key="additional_macros"/>
<description align="center" color="transparent" colored="false" width="126">Here the current value of att1 is extracted into a macro to use in the next operator</description>
<operator activated="true" class="generate_macro" compatibility="6.4.000" expanded="true" height="76" name="Generate Macro" width="90" x="179" y="30">
<parameter key="att2" value="%{att1} + (%{att3} * 0.5)"/>
</list>
<description align="center" color="transparent" colored="false" width="126">This operator generates another macro called att2 which is the final calculation based on the att1 &amp; att3 macro values.</description>
<operator activated="true" class="set_data" compatibility="6.4.000" expanded="true" height="76" name="Set Data" width="90" x="313" y="30">
<parameter key="attribute_name" value="att2"/>
<parameter key="value" value="%{att2}"/>
<list key="additional_values"/>
<description align="center" color="transparent" colored="false" width="126">Next we set the value of the current example of att2 with the value of the macro %{att2}</description>
<operator activated="true" class="extract_macro" compatibility="6.4.000" expanded="true" height="60" name="Extract Macro" width="90" x="447" y="30">
<description align="center" color="transparent" colored="false" width="126">Lastly we extract the current value of the attribute att2 and store it as a macro named att3. This will then be remembered in the next loop.</description>
<connect from_port="example set" to_op="Extract Macro (2)" to_port="example set"/>
<connect from_op="Extract Macro (2)" from_port="example set" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Set Data" to_port="example set input"/>
<connect from_op="Set Data" from_port="example set output" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_port="example set"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<description align="center" color="yellow" colored="false" height="128" resized="true" width="336" x="11" y="256">Because this is all happening in a loop there is no if statement required.</description>
</process>
<description align="center" color="transparent" colored="false" width="126">This loops through all examples. Note the iteration macro to keep track of the number in the loop.</description>
<connect from_op="Generate Test Data" from_port="out 1" to_op="Read CSV" to_port="file"/>
<connect from_op="Read CSV" from_port="output" to_op="Generate Empty Attribute" to_port="example set input"/>
<connect from_op="Generate Empty Attribute" from_port="example set output" to_op="Set Macro" to_port="through 1"/>
<connect from_op="Set Macro" from_port="through 1" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="example set" to_port="result 1"/>
<portSpacing port="sink_result 2" spacing="90"/>
</process>
</process>
