rapidminer code to xml
ashish0038
i m working on sentiment analysis i have got my result and improvement in rapidminer for my sentiment analysis . i wana convert this rapid miner xml code into the java code pls help me out in that i have search alot but couldnt find any answer relater to my work . this is really important for me so pls reply as soon as possible
my xml code is :
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="636" width="668">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="30">
<list key="text_directories">
<parameter key="negative" value="F:\fOR_FINAL_EXAM\dataset\for_database\Apex AD2600 Progressive-scan DVD player"/>
<parameter key="positive" value="F:\fOR_FINAL_EXAM\dataset\for_database\Canon G3"/>
</list>
<parameter key="encoding" value="windows-1253"/>
<parameter key="prune_method" value="percentual"/>
<parameter key="prune_above_percent" value="95.0"/>
<process expanded="true" height="490" width="673">
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="216" y="162"/>
<operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="292" y="247"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="421" y="338"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="x_validation" compatibility="5.3.000" expanded="true" height="112" name="Validation" width="90" x="313" y="30">
<process expanded="true" height="472" width="311">
<operator activated="true" class="support_vector_machine_linear" compatibility="5.3.000" expanded="true" height="76" name="SVM (Linear)" width="90" x="112" y="30"/>
<operator activated="true" class="k_nn" compatibility="5.3.000" expanded="true" height="76" name="k-NN" width="90" x="112" y="165"/>
<connect from_port="training" to_op="SVM (Linear)" to_port="training set"/>
<connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
<connect from_op="SVM (Linear)" from_port="exampleSet" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="exampleSet" to_port="through 1"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_through 2" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="51" y="56">
<operator activated="true" class="performance" compatibility="5.3.000" expanded="true" height="76" name="Performance" width="90" x="99" y="165"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_through 2" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="false" class="store" compatibility="5.3.000" expanded="true" height="60" name="Store" width="90" x="447" y="165">
<parameter key="repository_entry" value="store"/>
<operator activated="true" class="store" compatibility="5.3.000" expanded="true" height="60" name="Store (3)" width="90" x="112" y="300">
<parameter key="repository_entry" value="data"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Process Documents from Files" from_port="word list" to_op="Store (3)" to_port="input"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
</process>
</process>
Developer
Marco_Boeck
you want to simply execute the process via Java. To do that, please follow the instructions of 1) and 5) here:
http://rapid-i.com/rapidforum/index.php/topic,5807.0.html
Doing everything manually is possible but very complex, tedious, and frankly out of scope for this forum.
Marco
