<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="k_means" compatibility="5.3.015" expanded="true" height="76" name="Clustering" width="90" x="313" y="120"> <parameter key="k" value="3"/> </operator> <operator activated="true" class="cluster_distance_performance" compatibility="5.3.015" expanded="true" height="94" name="Performance" width="90" x="514" y="120"/> <connect from_op="Retrieve Iris" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Performance" to_port="cluster model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Performance" to_port="example set"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="5.3.015" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30"> <parameter key="excel_file" value="/home/andrew/Downloads/rapidminer/data.xls"/> <parameter key="imported_cell_range" value="A1:BA247"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="L6_01.true.polynominal.attribute"/> <parameter key="1" value="L6_02.true.polynominal.attribute"/> <parameter key="2" value="L6_03.true.polynominal.attribute"/> <parameter key="3" value="L6_04.true.polynominal.attribute"/> <parameter key="4" value="L6_05.true.polynominal.attribute"/> <parameter key="5" value="L6_06.true.polynominal.attribute"/> <parameter key="6" value="L6_07.true.polynominal.attribute"/> <parameter key="7" value="L6_08.true.polynominal.attribute"/> <parameter key="8" value="L6_09.true.polynominal.attribute"/> <parameter key="9" value="L6_10.true.polynominal.attribute"/> <parameter key="10" value="L6_11.true.polynominal.attribute"/> <parameter key="11" value="L6_12.true.polynominal.attribute"/> <parameter key="12" value="L6_13.true.polynominal.attribute"/> <parameter key="13" value="L6_14.true.polynominal.attribute"/> <parameter key="14" value="L6_15.true.polynominal.attribute"/> <parameter key="15" value="L6_16.true.polynominal.attribute"/> <parameter key="16" value="P12_01.false.polynominal.attribute"/> <parameter key="17" value="P12_02.false.polynominal.attribute"/> <parameter key="18" value="P12_03.false.polynominal.attribute"/> <parameter key="19" value="P12_04.false.polynominal.attribute"/> <parameter key="20" value="P12_05.false.polynominal.attribute"/> <parameter key="21" value="P12_06.false.polynominal.attribute"/> <parameter key="22" value="P12_07.false.polynominal.attribute"/> <parameter key="23" value="P12_08.false.polynominal.attribute"/> <parameter key="24" value="P12_09.false.polynominal.attribute"/> <parameter key="25" value="P12_10.false.polynominal.attribute"/> <parameter key="26" value="P12_11.false.polynominal.attribute"/> <parameter key="27" value="P12_12.false.polynominal.attribute"/> <parameter key="28" value="P12_13.false.polynominal.attribute"/> <parameter key="29" value="P12_14.false.polynominal.attribute"/> <parameter key="30" value="P12_15.false.polynominal.attribute"/> <parameter key="31" value="P12_16.false.polynominal.attribute"/> <parameter key="32" value="P12_17.false.polynominal.attribute"/> <parameter key="33" value="P12_18.false.polynominal.attribute"/> <parameter key="34" value="P12_19.false.polynominal.attribute"/> <parameter key="35" value="P12_20.false.polynominal.attribute"/> <parameter key="36" value="P12_21.false.polynominal.attribute"/> <parameter key="37" value="P12_22.false.polynominal.attribute"/> <parameter key="38" value="P12_23.false.polynominal.attribute"/> <parameter key="39" value="P12_24.false.polynominal.attribute"/> <parameter key="40" value="P12_25.false.polynominal.attribute"/> <parameter key="41" value="P12_26.false.polynominal.attribute"/> <parameter key="42" value="P12_27.false.polynominal.attribute"/> <parameter key="43" value="P12_28.false.polynominal.attribute"/> <parameter key="44" value="P12_29.false.polynominal.attribute"/> <parameter key="45" value="P12_30.false.polynominal.attribute"/> <parameter key="46" value="P12_31.false.polynominal.attribute"/> <parameter key="47" value="P12_32.false.polynominal.attribute"/> <parameter key="48" value="P12_33.false.polynominal.attribute"/> <parameter key="49" value="P12_34.false.polynominal.attribute"/> <parameter key="50" value="P12_35.false.polynominal.attribute"/> <parameter key="51" value="P12_36.false.polynominal.attribute"/> </list> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.3.015" expanded="true" height="94" name="Replace Missing Values" width="90" x="45" y="120"> <list key="columns"/> </operator> <operator activated="false" breakpoints="after" class="nominal_to_numerical" compatibility="5.3.015" expanded="true" height="94" name="Nominal to Numerical" width="90" x="179" y="120"> <list key="comparison_groups"/> </operator> <operator activated="true" class="guess_types" compatibility="5.3.015" expanded="true" height="76" name="Guess Types" width="90" x="313" y="30"/> <operator activated="true" class="k_means" compatibility="5.3.015" expanded="true" height="76" name="Clustering" width="90" x="447" y="30"> <parameter key="measure_types" value="MixedMeasures"/> </operator> <operator activated="true" class="cluster_distance_performance" compatibility="5.3.015" expanded="true" height="94" name="Performance" width="90" x="581" y="30"/> <connect from_op="Read Excel" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Performance" to_port="cluster model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Performance" to_port="example set"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_port="result 2"/> <connect from_op="Performance" from_port="cluster model" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
