🎉Community Raffle - Win $25
Join and Win
[SOLVED] how to set nested parameters for an operator in my own code
User: "mohammadreza"
New Altair Community Member
Updated by Jocelyn
Hi all,
I have the following operator in my process which contains a parameter with a list of parameters. I need to set the value of those inner parameters (i.e. the parameter with keys 'a' and 'b')  in my code. I was wondering if there is any way to do that programmatically.  --thanks
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="75">
       <list key="text_directories">
         <parameter key="a" value="C:\myFile1"/>
         <parameter key="b" value="C:\myFile2"/>
       </list>
ps. I tried to use setParameter( ) method but it accepts only Strings.
1 - 2 of 21
