<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="r:execute_script_r" compatibility="5.3.000" expanded="true" height="76" name="Execute Script (R)" width="90" x="447" y="345"> <parameter key="script" value="setwd("c:\\temp") png(file="plot.png") plot(iris) dev.off()"/> <enumeration key="inputs"/> <list key="results"/> </operator> <connect from_op="Execute Script (R)" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
