<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros> <macro> <key>counter</key> <value>1</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="246" y="300"> <list key="attribute_values"> <parameter key="counter" value="%{counter}"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="publish_to_app" compatibility="6.4.000" expanded="true" height="60" name="Publish to App" width="90" x="447" y="165"> <parameter key="name" value="report_variables"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Publish to App" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros> <macro> <key>counter</key> <value>1</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="recall_from_app" compatibility="6.4.000" expanded="true" height="76" name="Recall from App" width="90" x="179" y="120"> <parameter key="name" value="report_variables"/> </operator> <operator activated="true" class="text:create_document" compatibility="6.4.001" expanded="true" height="60" name="Create Document" width="90" x="380" y="300"> <parameter key="text" value="Counter : %{counter}"/> </operator> <operator activated="true" class="extract_macro" compatibility="6.4.000" expanded="true" height="60" name="Extract Macro" width="90" x="313" y="165"> <parameter key="macro" value="counter"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="counter"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <connect from_op="Recall from App" from_port="result" to_op="Extract Macro" to_port="example set"/> <connect from_op="Create Document" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
