Analyzing information for each cluster
carlitos_mg
I would need help and advice for this problem with RM. I am trying to cluster in 5 clusters and get the topic of scientific documents (I have it in PDF and in TXT and I tried with both so the format is not the problem). As you can see in the process after extract cluster prototypes I try to separate each cluster to analyze the most common words in every cluster and exctract the topic of them. I would like to filter the words, for example the ones that appear less than 0.01 using select attributes or remove useless attributes, but this operator is not working. I have to transpose the rows and then I can remove the words that have 0 value adding another operator filter examples. I tried to add text to nominal because I thought maybe RM does not detect that the frequency after separate the clusters is a number, but still is not working.
I hope you understand the proleblem. I write the code below.
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="75">
<list key="text_directories">
<parameter key="Fluid" value="C:\Users\Carlos\Desktop\Rapidminer\Data\Engineering\All TXT"/>
</list>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="30"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="45" y="120"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="179" y="120"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="313" y="120">
<parameter key="string" value="cluster"/>
<parameter key="invert condition" value="true"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.002" expanded="true" height="76" name="Filter Stopwords (Dictionary)" width="90" x="447" y="120">
<parameter key="file" value="C:\Users\Carlos\Desktop\Rapidminer\Data\Unnecesry words.txt"/>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/>
<connect from_op="Filter Tokens (by Content)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
<connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="k_means" compatibility="5.3.015" expanded="true" height="76" name="Clustering" width="90" x="45" y="210">
<parameter key="add_cluster_attribute" value="false"/>
<parameter key="add_as_label" value="true"/>
<parameter key="k" value="5"/>
<parameter key="measure_types" value="NumericalMeasures"/>
<parameter key="numerical_measure" value="CosineSimilarity"/>
<operator activated="true" class="extract_prototypes" compatibility="5.3.015" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="45" y="345"/>
<operator activated="true" class="multiply" compatibility="5.3.015" expanded="true" height="148" name="Multiply" width="90" x="179" y="165"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (6)" width="90" x="313" y="390">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="cluster=cluster_4"/>
<operator activated="true" class="transpose" compatibility="5.3.015" expanded="true" height="76" name="Transpose (5)" width="90" x="447" y="390"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (10)" width="90" x="581" y="390">
<parameter key="parameter_string" value="att_1=0.0"/>
<parameter key="invert_filter" value="true"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (5)" width="90" x="313" y="300">
<parameter key="parameter_string" value="cluster=cluster_3"/>
<operator activated="true" class="transpose" compatibility="5.3.015" expanded="true" height="76" name="Transpose (4)" width="90" x="447" y="300"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (9)" width="90" x="581" y="300">
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (4)" width="90" x="313" y="210">
<parameter key="parameter_string" value="cluster=cluster_2"/>
<operator activated="true" class="transpose" compatibility="5.3.015" expanded="true" height="76" name="Transpose (3)" width="90" x="447" y="210"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (8)" width="90" x="581" y="210">
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (3)" width="90" x="313" y="120">
<parameter key="parameter_string" value="cluster=cluster_1"/>
<operator activated="true" class="transpose" compatibility="5.3.015" expanded="true" height="76" name="Transpose (2)" width="90" x="447" y="120"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (7)" width="90" x="581" y="120">
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples" width="90" x="313" y="30">
<parameter key="parameter_string" value="cluster=cluster_0"/>
<operator activated="true" class="transpose" compatibility="5.3.015" expanded="true" height="76" name="Transpose" width="90" x="447" y="30"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (2)" width="90" x="581" y="30">
<connect from_op="Process Documents from Files" from_port="example set" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/>
<connect from_op="Clustering" from_port="clustered set" to_port="result 7"/>
<connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Multiply" to_port="input"/>
<connect from_op="Extract Cluster Prototypes" from_port="model" to_port="result 6"/>
<connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (3)" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 3" to_op="Filter Examples (4)" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 4" to_op="Filter Examples (5)" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 5" to_op="Filter Examples (6)" to_port="example set input"/>
<connect from_op="Filter Examples (6)" from_port="example set output" to_op="Transpose (5)" to_port="example set input"/>
<connect from_op="Transpose (5)" from_port="example set output" to_op="Filter Examples (10)" to_port="example set input"/>
<connect from_op="Filter Examples (10)" from_port="example set output" to_port="result 5"/>
<connect from_op="Filter Examples (5)" from_port="example set output" to_op="Transpose (4)" to_port="example set input"/>
<connect from_op="Transpose (4)" from_port="example set output" to_op="Filter Examples (9)" to_port="example set input"/>
<connect from_op="Filter Examples (9)" from_port="example set output" to_port="result 4"/>
<connect from_op="Filter Examples (4)" from_port="example set output" to_op="Transpose (3)" to_port="example set input"/>
<connect from_op="Transpose (3)" from_port="example set output" to_op="Filter Examples (8)" to_port="example set input"/>
<connect from_op="Filter Examples (8)" from_port="example set output" to_port="result 3"/>
<connect from_op="Filter Examples (3)" from_port="example set output" to_op="Transpose (2)" to_port="example set input"/>
<connect from_op="Transpose (2)" from_port="example set output" to_op="Filter Examples (7)" to_port="example set input"/>
<connect from_op="Filter Examples (7)" from_port="example set output" to_port="result 2"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Transpose" to_port="example set input"/>
<connect from_op="Transpose" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_port="result 1"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
<portSpacing port="sink_result 8" spacing="0"/>
</process>
</process>
Thank you very much.
Clustering
carlitos_mg
I don't know why is added an emoticon when I write the code.
