I'm not quite sure if it's a bug, or if I'm doing something wrong. I used the "loop attribute" operator to loop over my attributes. Inside the "loop attribute" I have only the filter examples - operator. The settings for the "filter example" operator and the error are below. The macro does work, if i change the inner operator to the e.g. "aggregate"-operator. With the "filter example" operator there seems to be a problem though. Is this a bug??
edit: the operator seems to recognize the macro when I use the "expressions" settings, but again not for the "custom filters" settings.
Thank you!
Parameters for "loop attribute" operator
Filter example settings
Error
